What(39)s inside the water heater -- how fast will it heat-gctid816417
    Across the years there have been a number of questions about how fast a water heater should heat with just the engine coolant flow.
    A little bit of thermodynamics and a sprinkle of math can solve that.
    To do that I need to know what's inside the heater. I know there is a coil of metal tubing.
    How long is it, whats the diameter and what is it made of? I think it's smooth on the outside rather than having fins.
    Thanks!
    Foster
    Thanks!
    Foster
    [color]blue wrote:
    Most are built using smooth OD tubing that makes a loop. No heat sink/fins...... Nothing fancy!
    My 12 gallon SS Water Heater will produce hot water in approximately 45 minutes of cruise time (no electric heating during this).
    The key is in how the Engine Coolant supply/return are plumbed at the engine.
    Many get this wrong, and it reduces the effectiveness.
    [/color]
      My six gallon heater will produce hot water in about 15 minutes of normal cruise rpm 3400-3600 or so.
      2007 Discovery 246
      300mpi BIII
      Welcome island Lake Superior
        Thanks for all the replies.
        I'm looking for some science. I can build the math to say X amount of water at Y temps will heat Z gallons in T time.
        What I need is the heat input, how big is the hot tube in the tank. For example, if the tube is 3/4" and 4' long at 170 degrees (average temp on a diesel) it will take 72 mins to heat 11 gallons of water 70 degree water to 170 degrees. A 1" long tube will take close to 6 days to do that.
        How long / diameter of the heating tube inside?
        Who has a sazall and a few mins to look?
        Thanks!
          Or you could simply say, "Hey Susan, is the water hot enough for my bath yet?"B)
          Jeff & Tara (And Hobie too)
          Lake Havasu City, AZ
          And 13 others...
            We are avoiding the "WTF Foster, what is up with the hot water for MY bath". Pay attention here :-)
              Thanks!
              I have a sawzall. Ship your water heater to me and I will answer all your questions.
              Esteban
              Huntington Beach, California
              2018 Element 16
                [color]blue wrote:
                Foster, I would contact Atwood, Seaward, Kuuma, Raritan, etc, and ask just how their engineers determined the size/length of the internal Heat Exchanger tube in order to come up with a proper design that works in most scenarios. :P
                I'm just poking fun at you...... no offense! [/color]
                  If you're really looking to do an analysis, why not conduct an empirical analysis. Measure and log the temps of the engine coolant and the temp of the potable water from the heater over time. You could then derive a thermal heat transfer coefficient, which would allow you to back into the heat flux numbers.
                  Then you could tell the wife that once you get the thermostat open, she gets XX minutes of hot water for every XX minutes of running.
                  iBoatNW
                    Just remove the bathtub, problem solved :silly:
                      Yes..... that and the washing machine and the dishwasher.
                        Hey, since you're into doing math.....
                        How long would it take 400w @ 17V of PV panels to heat 11 gallons of water from say 60F to 110F?
                        Terry
                          does anyone can help me on that, I think I left my water heater breaker ON with no water ....
                          I need to know the replacement part number
                          tks
                            You can buy replacements at most hardware stores. Here in Canada, about $30.00
                            The element with the square mounting flange can be installed in any orientation, but if you look closely there is an arrow pointing up that orients the heating loop vertically. I would guess it is stronger in that position.
                            2007 Discovery 246
                            300mpi BIII
                              Not sure if you're joking, but water has a specific heat of about 4.178 kJ/kg-C in that temperature range..
                              http://www.engineeringtoolbox.com/wa...ies-d_162.html
                              11 gallons of water is 41.64 liters = 41.64 kg.
                              110F - 60F = a change of 50 F. Divide by 1.8 degrees F per degree C to get a change of 27.8 C
                              (4.178 kJ/kg-C) * (41.64 kg) * (27.8 C) = 4836 kJ = 1343 Watt-hours
                              Average capacity factor for solar in the U.S. is about 0.135, so over a year your 400 Watts of panels will produce on average (400 W)*(0.135) = 54 Watts. So it will take about (1343 Wh) / (54 Watts) = 24.9 hours. Basically one day's panel generation (since the average is spread over both day and night). There are no efficiency losses since the end product is heat, but there will be some heat losses due to (lack of) insulation. So expect it to take a bit more than a day.
                              If you want to get PV production for a specific location and time of year, use the government's PVWatts site:
                              http://pvwatts.nrel.gov/
                              Note: Water has a very high specific heat, so it takes a lot of energy to heat it up. Instead of using an electric heater, whenever possible you are much better off using waste heat from other sources (e.g. the engine) to heat up water.
