Hi all,
On my 454 crusaders the stbd engine oil pressure gauge bounced occasionally between ~32 and ~42 . No issues with the engine, runs awesome, no oil burn and the gauge is brand new. Could a sender going bad cause this? Could it be an actual engine issue? or is this normal? I dont think its normal as the port engine stays steady-ish between 39-42. All this is during constant rpm's, not between idle and power. Any thoughts? I tried to explain as I saw it but if you need more info let me know. What can I check from here?
