So I've just bought a new Rule Gold series 2000 gph bilge pump and a Ultra junior float switch to go with it, to replace my existing aft pump in the engine room..... which is fairly small (I think only 500gph) with a non-functioning float switch wired to it. Pretty sure it's wired as described in this old thread:
http://www.baylinerownersclub.org/in...-pumps-on-2855
I also bought a new rule 3 way switch to go with it... auto, off or manual. BUT... I'm wondering now with my setup, and based on what I've read in the thread above... do I even need the 3-way switch? I was planning to wire it into one helm and basically leave it set to auto... but if my existing setup is currently designed/wired to be always on auto already, with either of the helm switches for over-riding that, then I presume I'll be able to wire my new pump and switch into this without pulling new wiring to a helm?
Anyone know.... or done this, with this setup on the same or similar boat?
Thanks.
Thanks.
