Had to remove the fridge on my 1999 2452 to do some upgrades and noticed the rear box fan was smashed to pieces. So I ordered new from fan mfg to replace thinking the PO may have done damage over the years. After replacing fan the fridge would not return to the opening. Would not go flush. It was the fan stopping the installation. Am assuming that maybe Bayliner smashed the fan originally as it just would not fit. Removed the mounting and zip tied the fan to the coil frames and it finally went back in flush. Just thought I'd give a "heads up" on my issue. Wonder how many others are broken the same from production?
1999 2452 Norcold fan destroyed-gctid815996
