Anyone know if this will work with my boat? I already have the NMEA2000 set up, just need to know what I need to view my engine gauges on my chartplotter.
Engine Gauges on Garmin 741xs NMEA2000 Chartplotter-gctid815912
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
KevinTags: None
Your engine has analog inputs. In order to convert these to NMEA 2000 you need one of these: http://www.nolandeng.com/rs11.php
2013 Boston Whaler 130 SS
Isla Verde, PR
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Here is another thread:
Isla Verde, PR
http://www.baylinerownersclub.org/in...e?limitstart=0
[attachment]38667 wrote:
BonDCHelm.jpg[/attachment]
My intention is to move the 741xs up to where the 198C is to use mostly for the engine stats, then pick up a 10" or 12" chartplotter to take its place. The tach is intermittent, yet the signal seems to be continuous, so I'm hoping this will fix the problem. Also, the fuel gauge reads beyond full until the level drops below ÔàØ of a tank, then it reads ┬¥. I don't know if this will fix that problem, because it may need a new sender. The speedometer quit last trip out, though I never use it anyway. The oil pressure gauge also reads high - at least, it appears too read high, as you can see on the far lower left, even after new oil and filter.
Again, thanks.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
