As having the engine out, decided to pull the tank of my 2556 project boat. Fish well removed, part of the bulkhead towards the engine stringers cut down, beam over tank removed and some fiberglass
holding tank down removed. All done using a multi tool cutter, not to bad of a job. Want to check for corrosion, most likely need to renew the tank as its original from 1990.
Need to remove some fuel before staring to removing it, my question , is this preparation work sufficient or do i still need to do some cutting to remove the tank?
