Im not sure what the best course of action is here... Last summer I bought a 1986 Bayliner Capri 1950BR with a Volvo Penta 280 outdrive, and Volvo Penta 225D 5.0L engine. I removed the water drain plugs to winterize the boat, and when I tried to put the plugs back into the bottom side of the engine block I saw that they are terribly stripped, and wont go back into the block. When I try to screw them in, they basically start threading, then just break loose and start again, break loose and start again, and wont go in deep enough to stay. The two on the back of the manifold at back of engine went back in fine. There are pictures of the drain plugs below. At this point Im not sure if a previous owner tried to drill out and tap the engine holes to increase the size of the plugs, or if these are the original plugs. I cant really get close enough to the holes to see if they are badly stripped. I've done a little reading and I think I understand the concepts of thread chasing and tapping a LITTLE, and it sounds like something I dont have enough experience to do, and also like doing it with the engine in the hull is a problem... The local boat repair shops in Colorado Springs basically sent me packing when I asked them about checking the engine over last year, but they gave me the name of a retired guy who worked on old boat engines, who I can no longer get in touch with...
Any suggestions or advice? Should I first try getting replacement plugs in the original size, and see if they will go in? Where do I get new drain plugs? how much does the length of the plug matter? I saw a couple of posts about putting in a petcock that with loctite that looked great, but Im not sure if that's too much of an unknown at this point (http://www.baylinerownersclub.org/in...-volvo-aq260)? How do you go about trying to use a thread chaser, and should I try? If you have to use a drill or something, seems like that's going to be problematic on the port side since there is not a log of space there.
Any advice would be greatly appreciated...
