Hi all I have decided to spring for a flow scan system, but need to be educated, locked back in search did not find much so need some help.
Flow scan info?-gctid815393
Thanks for the response's, the seem to be several models to pick from and yes I know single or twin make a difference as well as Gas to diesel. Are your units displaying a link to the GPS ? PS I have installed a Diesel.
I installed a floscan on my starboard engine a few years ago and got a good picture of fuel burn vs rpm vs speed. A friend has a 2858 and installed one on his and is pleased with it.
MMSI: 338030604
I don't remember the exact prices, but it wasn't a lot more for one with a GPS interface, and MPG data makes more sense to me than GPH in terms of efficiency. If you don't already have a GPS on board you might take a look at this thread:
http://www.baylinerownersclub.org/in...owscan-and-vhf
1985 Bayliner Ciera 2750
300HP Volvo Penta 5.7 with DP-A drive
