Forward and Aft Bilge Pumps-gctid815249
    It rains a lot here in South Florida during the rainy season. Both the forward and aft pumps do not go on when they're set in the Auto position. I have to turn them on manually at the toggle switches. A lot of water does drain out for both pumps. I also get a lot of water build up because I'm also running the A/C. Has anyone had this problem? Any advice or help would be greatly appreciated.
    Thank In Advance,
    Chuck
    1999 Bayliner Ciera 2655
    5.7 Liter Bravo III
    Check to see if there is 12 v power to the float switches! you may find that there is a fuse inline with them or that they are not functioning!
    Mine have a fuse for each pump float switch!
    Good luck and keep us posted as to your progress!
    Don
    1988 Bayliner 2455 (sold)
    1976 Tahiti 16.5 I/O (sold)
