Hey folks,
My boat has 2 starting batteries and is connected to a selector switch for (1-2-all-off) selection, I believe it is a Perko switch. I want to add a fuse block AFTER this selector switch.
Is there a specific type of fuse block you would recommend for this type of application, which will be located in the bilge compartment? Or is any marine grade fuse block acceptable?
Thanks for your input!
