My Force 125 water is not flowing out well. Impeller replacement or water pump?-gctid814713
    That is normal, they are pressure relief holes not a tattle tale like other outboards have. Force engines don't have a tattle tale but I think you can add one. If your impeller is more than two years old you should replace it imho.
    I would advise you test your overheat buzzer also. If mine had worked mine might still be running.
  • My Force 125 water is not flowing out well. Impeller replacement or water pump?-gctid814713
    Only after running at higher RPM's does the water come flowing out of impeller ports. Service manual is not clear and I don't see any good videos on youtube
