Hello all, I picked up a 1988 Capri with the OMC 3.0 last year and have been messing with getting her back up to speed. The boat starts up and will run wide open for about 20 min or so then slowly starts to bog down and eventually die at which point you can restart in neutral and rev/throttle all day but once in gear it won't throttle up, it has a bogged down sound when I try.
It was converted to electronic ignition before I got it but I do not see where the "diode fix" is in the wire between the coil and the shift assist, Could this be my issue? I am not sure If the conversion was done after the prior owner took it out of the water for the last time or if he was running it with the current setup, The boat sat for three years before it was given to me.
I have cleaned out the fuel tank and pump and replaced fuel lines and replaced the coil. Thanks in advance, T
