I'm in the process of mounting up a Lowrance HDS-7 and the LSS-2 on a 28' bounty and was wondering if anyone else has had any problems with the LSS transducer getting damaged or problems with clipping from the drives (I/O) when mounted low on the transom next to the bilge drain. The bracket that comes with it is the same for the LSS-1. Which is im my opinion pretty cheesy for the almost 11" long transducer of the LSS-2. Just curious if anyone has some experience with this system and how they mounted the transducers.
Thanks.
Brandon
Thanks.
Brandon
