1993 Bayliner Ciera 2655 power steering problem-please help-gctid398335
    We have a 1993 Bayliner Ciera 2655 that is losing power steering fluid-it was empty, we filled it then when we came back it was empty again and all in the bilge when we got back to shore. Signs by pump were dry-no signs by leak by rack...only two lines transfer fluid from pump to rack...any suggestions? Thank you in advance for your help.
    John
    it's leaking somewhere, just need to look harder.. get inside the engine compartment with a flashlight while someone turns the steering wheel... just be careful not to get caught in the belts...
      Could it possibly be the power steering cooler?
        just had to tighten the hose clamp ops
          it's happened to all of us glad it was a simple fix...
