I bought a 2007 246. Trying to figure a couple of things out.
There is a thick, red wire in the engine compartment that is not attached to anything. It passes through the bulkhead, on the port side, heading forward. The end of the wire can reach the batteries, but the eye on the crimped fitting is too small. It does not appear to attach to the onboard charger; there are two smaller red and a yellow attached to the charger on the charger's bottom left side and no open studs.
However, the onboard charger doesn't seem to work. Is there a specific setting the batteries or panel need to be on for it to work?
Also, the panel will not energize unless the onshore power is plugged in. Again, is there a specific setting I might be missing?
Thanks,
Adam
Thanks,
Adam
