My Honda generator is starting with no problems but when we put load on it a large amount of white smoke starts to come out of the exhaust. It is not a blown gasket as there is no sign of any problems in this area. Can anyone offer me an easy fix.
Honda EU65IS Generator-gctid814054
If it has high hours its probably burning oil. I have had 3 Honda generators do this to me. Usually the EU series are good for around 500 to 700 hours and then thats about it. I know that I will be thoroughly scolded for my next statement but I will no longer purchase Honda products due to poor durability.
1988 Mainship 36 Sedan
1995 2858
1988 2655
1987 2150
Commercial/Industrial HVAC Service Tech.
Its done less than 50 hours but has been not been started for some time. I will change the oil & let you know the result. Thanks for your input.
"RPrather" post=814056 wrote:
Try changing the oil and see if it clears up. Also do NOT attempt to use synthetic oil as it will foam up.
"REEL WILD"
2001 2859 FNM 300 Diesel-Bravo 2
Anchorage, Alaska
If you don't like the weather, wait 15 minutes.......
2013 Boston Whaler 130 SS
Isla Verde, PR
We changed the oil & cleaned the fuel system but still white smoke when under load. It stalls after a few seconds of the white smoke starting. What can it be.
We did some more cleaning & added plenty of Carburetor cleaner & its looks like the problem is solved We will run her all Saturday night which will be a good test.
I'm glad to hear that the problem was solved.
To avoid it in the future try to use non-ethanol gas and add Stabil to it. Also, start and run the generator for 15 minutes monthly. Try to put a load on it when you do this. I use space heaters for the load.
Isla Verde, PR
We had her running fine but when we switched on the air con it would stutter & stall. We found an O ring that was perforated on the fuel off/on valve so changed it & she is running better than ever.
