First test run of new boat was mostly successful. Boat ran great, but the steering is nearly locked up and takes two strings hands to twist. I believe I have verified that it is a seized cable, as I removed the rod from the drive itself, which the drive moves fine. R & P steering system.
I am having trouble locating the part number and/or length of the cable to order. I couldn't find it on the cable when following up under the he'll, just markings of Telefax w/o numbers.
Does anyone have the part number or length of this cable? Manual for this year and model boat (cant find in the manual links through BOC). Trying to get it without removing so I can spend a few hours swapping out as we are officially in season
Thanks in advance!
Thanks in advance!
