Learned scholars I seek your advice and help.
I have a 1990 capri with the I/O 3.0 l merc. I pulled the engine as the block has an internal leak / crack and have been fortunate enough to find a 2000 motor with an intact block.
I am currently going to rebuild the 2000 (serial # L654438 ) which I believe is an Alpha 1 .
My question is this, The new engine has no distributor or any of the other components of the electronic ignition, yet the older motor is intact. Is it possible to convert the new motor to old ie points, distributor , etc or use the old distributor and modify it to be electronic, or is there an automotive ignition I can adapt ?
I am trying to get this back up and running but without spending a fortune .
Any help is greatly appreciated,
thanks in advance
Andy
thanks in advance
Andy
