I was running the engine at home with water muffs to check it out for this season. It was idling when I turned the ignition switch off, but the engine kept right on running at an idle. I had to cover the carb throat with my hand to stop it. I checked the switch with an ohmmeter and it is functioning properly. Any suggestions on where to look next?
2.3l Ford engine won(39)t shut off-gctid813549
My first thought would be the ignition switch went.
Next time pull the coil plug off the dist, use a tool with taped handles .
Engine starts with the key, won't shut down with the key.
Your coil feed wire must be hot,
Main barrel plug,
I'm going to look for the free d/l for you will have the electrical diagram.
Edit:
Page 10-59 you might have to use your keyboard arrows to navigate the site.
http://boatinfo.no/lib/omc/manuals/1...manual.html#/2
