Hello all. I have a 1988 bayliner with the 2.3L I/O. I bought this from my Dad well over 10 years ago and have ran the tar off of the thing!! Been running great after I had some work done the first couple summers. I live in Northern Wisconsin so obviously fresh water.
Here is my issue. I found some water in the fuel last summer. I emptied the fuel filter/water separator several times before I drained the whole tank through the fuel line. I refilled the tank with new fuel and it ran great the rest of the weekend. A couple weeks later I returned to my boat, which I keep on the lake with a nice cover, but it still ends up damp on the inside. I always have to run the bilge when it sits. Once I fired the boat up again I found water in the fuel again. This is basically how my summer ended.
Fast forward to this spring...I drained the fuel out through the fuel line again, I mean the line which leads directly to the fuel filter. I added 10 gallons of new fuel plus a bottle of HEET, the yellow one. I figured this should be the remedy I needed but once I got it into the lake I ran into the same issue again. Boat fired perfectly and idled just fine. once I started to take off and the engine had a load under it, it bogged down so I throttled back to neutral and kept it running. Once I pulled the fuel filter/water separator off it was plum full again. I dumped it and tried roughly 4 or 5 more times hoping it was the very end of the water. It unfortunately wasn't.
Since the whole system is enclosed, where could the water be coming from??? The way I see it there is no possible way there is this large amount of water in the fuel tank. I just can't see it happening. Is there a possibility that water is leaking through the fiberglass and getting into the fuel tank? I haven't seen or smelled any fuel leaking.
Any help would be great!!
Thanks from a fellow boater.
