1995 bayliner 2052 ls cuddy
4.3 l lx w/ 4 barrel carb
The engine will stall out if I go from idle to full throttle under load and not under any load.
If i give the engine 1/8 to 1/4 throttle and then gradually up to full throttle the engine accelerates perfect.
Other than the problem stated above the engine runs and starts with no problems.
Can anyone help me trouble shoot this problem or what things to check?
what I have done already
Fresh gas
New water fuel separator.
Thank you
Fresh gas
Thank you
