This happened to me a couple weeks back now, but I've only just now had a chance to post about it. It's a long post, so you can just read the TL
R if you want
TL
R - My raw water pump idler pulley bearing failed, it was a cheap and easy fix... but I am wondering about belt tension on that belt. Service manual says you should be able to depress the belt 1/4" when properly tensioned... but how much force should it take to do that.... just a light touch with a finger? Paranoid about putting too much force on the raw water pump pulley, but that pump turns fairly hard (ie. I can turn it by hand ... but it's not easy) so without a reasonably tight belt it slips and squeals a bit.
The full story:
The family and I were out on our first proper outing of the season second last weekend in May. Had a beautiful time, cruised down to Orcas Island from Point Roberts on the Saturday morning, spent some time walking around Obstruction Pass state park, then anchored overnight at Lieber Haven Marina Resort. Next morning headed up to Rosario, stopping off at Olga on the way. Had another nice night at the Rosario marina, met up with my sister who came up from Edmonds for the day. Set off late Monday morning to make our way home. Boat was purring like a kitten the entire trip...
....until....
Just as we were turning to head into Obstruction Pass, maybe 15-20 minutes into our trip home.... I suddenly hear this loud buzzing... it was so loud I looked up and behind me expecting a seaplane was flying low above me.... but just as I did that, the engine just dies... no hesitation, just 3800 RPM to zero in a few seconds. I open the engine compartment, it's HOT... smells bad like something burning... and I'm thinking the worst... somehow it's seized or something. Like others I'm sure, I am pretty vigilant about constantly scanning my engine temp and oil pressure gauges.... just habit from growing up on a farm and operating heavy machinery much of my life... drilled into me by my Dad from a young age. So I knew that within the past 5 minutes or so of this happening, I had normal engine temp and oil pressure. But now.... engine is very hot... gauge is reading in the mid-200's. We're drifting with the current ... we were in around 80 ft of water but rapidly getting deeper as we drifted out into the main channel of the pass... so I dropped my anchor and got myself hooked.
Turned the engine over a few times... it turns over, so not seized.... but won't run. I take a closer look around the engine compartment... and spot this. The belt wasn't actually off, which is why I hadn't immediately noticed it, I pulled the belt off afterwards:
Here is whats left of that idler pulley.... bearing seized and the heat melted the plastic pulley.
So... looks like that bearing got nice and hot... melted the pulley off, stopping the raw water pump, the engine overheats very quickly but since the fuel pump is attached to the raw water pump the engine can't keep running (I always wondered about that design decision, but it sure makes sense to me now
) It's actually something I could have fixed on the water... but who carries a spare like that? I even had a spare belt for it... but no pulley. So... TowBoatUS to the rescue. We were very fortunate, there was a boat with a captain on it immediately ready to go from Friday Harbour and they were with us within 45 minutes. Unfortunately, it took 6 1/2 hours to get back to Point Roberts due to adverse currents... we could barely make 4 kts.... but I'm just happy we were 100% covered as the invoice was just over $1700 :blink:
So I replaced the pulley and belt, and things are good again... entire fix was under $50, but I'm wondering a couple things:
[ol]
[li]How easy (or hard) should that raw water pump turn by hand? It takes some effort to turn it, not sure if this is normal.[/li]
[li]The service manual says one should be able to depress the properly tightened belt approximately 1/4" ... but again, not sure how much force one should be applying to achieve this. Without this belt reasonably tight it squeals due to point 1 above,[/li]
[/ol]
TL
The full story:
....until....
[ol]
[/ol]
