Arch Construction-gctid813023
    What lays below the padded vinyl? Plywood, fibreglass?
    I'm thinking about fastening (screwing) a Ram Mount ball there.
    Wet'ever
    1989 Avanti 2955
    460 Cobra
    My impatient self drilled into it. My thought was, regardless of the material, that was where I wanted the ball.
    Based on the drill shavings it appears to be wood.
    Cockpit TV mount done!!
    Wet'ever
    1989 Avanti 2955
    460 Cobra
      On mine it's basically hollow and the fwd and aft edges have angled approx. 1.25" x1.25" wooden stringers that the upholstered panels attach to so most likely you saw sawdust from the backing panel of the padded panel. When I bought mine last July the stringers were rotted so I removed it for refurb and upgrades. Below is a view looking from the base of the side, narrowing as it reaches the bend/ transition to the top.
      Sold:
      Mariner 150
      Towing with:
      Near High Rock Lake, N.C.
