2017 Bayliner VR5 Jensen Radio-gctid812799
    Took my covers off today to head out for the second time only with my new VR5 that at that point only had 1hr run time and this is what I discovered when I turn the radio On.
    I've emailed my dealer and Bayliner.
    That sucks. Call your dealer, I would think they would replace it.
    FISHING ISNT A MATTER OF LIFE AND DEATH ITS MUCH MORE IMPORTANT.
    2016 Bayliner 195 deckboat
    220hp 4.3 MPI
      Dealer and Bayliner were contacted and it was said A) either defect in that radio or B ) it was installed too tight. Either way it's being replaced under warranty.
        Old thread but wanted to update. The stock unit ended up being replace twice. Now the current unit is the third unit in my boat all it appears to be holding up...... I always suspected either defect in materiel or installation hole too tight and this year I found my Trim gauge busted in two, found the installation hole was way too tight and left no room for expansion from heat.... Dealer didn't want to replace under warranty since the warranty had been over by 4 days.
