I find the contacts in my distributor cap getting corroded fairly rapidly. I warm up my engines every couple of weeks, and I find a layer of green corrosion on the contacts after a couple of months. I clean with contacts with a Dremel brush and the green corrosion comes right off. The engine starts and runs nicely with the distributor cap cleaned.
Have you faced the same problem and how do you solve it? Is it okay to coat the contact slightly with dielectric grease to prevent the corrosion?
Thanks,
Joe
Thanks,
Joe
