This problem is occurring on a 1992 3888 with the 210 HP Hino engines. Two new group 27 start batteries that test good. Alternators recently rebuilt. All was operating well until a couple of days ago when some of the gauges began to flutter. Now with the key starter switch "off" there is 13.4 volts present at the circuit breaker, start switch, stop switch, and preheat switch. When the key starter switch is turned to "on" there is no voltage at any of the aforementioned switches. The circuit breaker at the solenoid checks out OK, but no voltage either. I am hoping that someone else has had and solved this same problem. Your help is wanted, please.
Greg
Greg
