My prop slip is ridiculously high, any ideas why?
Clean bottom, new props, my boat might as well be going through glue!
My boat is a 288 Bayliner 288 with a 4.2 D-Tronic 250hp.
I have been running the prop calculators and released that my prop slip is absolutely awful, my setup is
Bravo III 2.20 ratio leg, using a 22P prop, 3800RPM, a WOT speed of 22 knots
i have also tried a set of 25P props, 3600RPM a WOT speed of 24 knots, but it was a dog getting out the hole and felt like the engine was lugging through the rev range.
A cording to the calculators my slippage is really bad nearly 40% am i doing something wrong here???
I just ordered my self a new set of 22p 4x4 props from hill marine, hoping it should help with this slippage.
