After finding out I had 60 gallons of watered down fuel in my 2006 242EC I had tank drained, flushed and filled with new fuel. All set to start her up, turn key, single click..NOTHING, turn key again, single click..NOTHING. Turned on cockpit lights and watched to see if lites dim when turn key..No, nice and bright. Checked voltage at batteries, voltage at starter..all good.
Could it be the slave solenoid?
If it is starter I feel like I have to remove manifold and riser to get at it. Slip neighbor tells me when I remove raw water hose from raw water pump, water will come gushing in from outdrive?
