I have an 88' Capri Cuddy 1950 with 5.7 Cobra. It's in good operating condition. My question is about my kicker motor. I bought the boat with an Evenrude 7.5 kicker that runs and operates well. It just doesn't push the boat very well, too small of a kicker for that size boat. My next door neighbor has a Johnson 25 horse that needs either to have the top end rebuilt or replaced. He says it works well except that the top end seized because the water pump failed. He is looking for a new motor and I was telling him about my Evenrude. He doesn't have the money for a new motor but he said he will trade me straight across, the 25 Johnson that needs work for my running 7.5 Evenrude that is ready to go. I can do the work in my shop to repair the Johnson no problem. Does that sound like a fair deal to you guys who know? I really want a bigger kicker motor and the Johnson would be that motor once I make it run again.
outboard motor trade-gctid812157
My first question is, what are you planning to use the boat for with that much kicker?
I have a 15hp on my 24'er, and it is more than I really need. I troll at 3mph just past the top the warm-up idle.
As to the exchange, is it worth it to you?
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
"Skutt" post=812165 wrote:
It would be for trolling or to get me back to the dock if the main quits for some reason.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
I'm sure your neighbor would be happy to trade his non running 25hp motor which is most likely toast, for a running 7.5. For years I had a 5hp 4str Merc on the back of my 2000 1802 Capri Cuddy. It pushed the boat quite well, even with 3 people in it. Your 7.5 should push yours quite well...is the prop and cavitation plate under the hull? Maybe you need to go down a pitch or 2 on your motor...If you have a say a 9P, go down to a 7P.
