I'm still struggling with the low water flow issues and high rpm overheat, looking to put in a seawater strainer thru hull for raw water pickup and be done with it!
Wondering if anyone has done this on a similar single engine boat (2855) and pickup location. I've read that some people just T into the outdrive pickup, while some cut the S hose short to allow some cooling water thru the drive still? Any ideas and advice appreciated, especially in regard to loactaion and what to use to seal the drilled surfaces thru hull-
