98 2355 water pump and fridge issue-gctid811586
  • 98 2355 water pump and fridge issue-gctid811586
    I recently bought a 98 2355 and have taken it out a few times and absolutley love it however a couple issues have popped up.
    #1 the water pump worked fine at first now it does not turn on, is there a fuse or something simple i should check first
    #2 the fridge same thing worked fine at frist now it does not run off of dc power, i have not been able to hook up shore power yet to see if it work off of that, but i ca not find a fuse for that either?
    any help is appreciated
    1998 bayliner 2355
    mercruiser 5.7
    alpha one
    1 yes should be an inline fuse near the pump.
    2 also fused probably under the helm.
    Both these issues happened around the same time? Check the negative connections for both those items and the confections at the negative buss at/near the fuse panel.
    Put your boat details in your profile/signature.
    Welcome to the club
      I beleive the water pump is in the engine bay ? and i do not see a inline fuse near it. i checked the fuse panel under the helm and do not see any blown fuses. the fridge and the water pump didn't stop at the same time but within 2 days of each other.
      1998 bayliner 2355
      mercruiser 5.7
      alpha one
        Are you referring to the water pump for fresh water from your sink? If so, it should be found under the stairs leading to the cabin.
        Simo
        2002 2855 350MPI Bravo III on Lake Champlain -> SOLD!
        Shameless lurking on Lake Keowee with a Harris Cruiser 210 Tritoon/Mercury 150XL EFI
          got both the fridge and the water pump working today, it ended up being a lose ground under the helm. Thank you guys for the help
          1998 bayliner 2355
          mercruiser 5.7
          alpha one
