Good resource for Switch Panel Fasteners-gctid397996
    Hi,
    I'm planning to replace switches on the dashboard. I would like to know if anyone has a good resource for switch panel fasteners (I think they're called canoe clips). I have an '89 2755 Ciera Sunbridge. Thanks in advance.
    John
    These guys are down the street from my shop, they've got it all! Don't know how to cross-reference the clips, but you may be able to shoot them a pic in an email? Cheers-Mike
    http://www.hillcofasteners.com/default.aspx
      Thanks Mike,
      They have everything but canoe clips. Nylon push clips would work too (two piece rivet type.) The don't have them either.
        Don't know what your canoe clips look like, but check McMaster Carr, they have a section of "canoe clip"s which are some kind of plastic rivet - http://www.mcmaster.com/#canoe-clips/=ic1hs7 . They also have all these - http://www.mcmaster.com/#standard-nylon-rivets/=ic1q6i .
          jregan11 wrote:
          Hi,
          John
          I was able to locate fasteners suitable to the task.... at autozone (go figure). http://www.autozone.com/autozone/acc...mString=search
          Thanks for everyones' suggestions.
            I was also looking for replacements, if you google Click-Lock Shank or nylon snap rivets, they look very similar to the style currently on my 1990 dash.
            http://www.mcmaster.com/#standard-nylon-rivets/=14oossc
            Where it actually covers the top like a cap.
