Faria 2(34) depth gauge - not a direct replacement for Standard Horizon DS41 etc.-gctid811172
    Hi,
    I just heard back from a very nice chap working for Faria's UK distributor (ASAP-Suppliers). The 2" Faria depth gauge uses 235Khz transducer frequency rather than the standard 200Khz so they will never work with another manufacturer's transducer. I just added this as a library entry for anyone scratching their head as to why their new gauge won't work without the manufacturer's sender.
    Terry
    Terry (Retired Diving Instructor and Part Time IT Consultant)
    1998 Bayliner 2452. 5.7l V8 - Edelbrock 1409 4bbl - Alpha1Gen2 - Solent UK.
    MMSI 235061726
    Just to finish off: the new 235 Khz transducer works really well. It is the puck type (thru hull) and I installed it in a bath of chainsaw oil (thick and sticky) on the dry side of the hull below the deck. The hull is at a slight angle but the puck has enough room to sit vertically in the bath. The oil is so thick that it doesn't move around much. I am quite pleased with the results.
    MMSI 235061726
