I've got no spark coming from ignition coil. I've replaced the coil and coil wire...still no spark. I checked fuses behind dash...all are good. Don't know where else to check. Boat turns over good, it's getting fuel.... it has the 3.0 mercruiser with the digital electronic ignition. Any help??? Stuck at the lake with a non running boat. Ran great last year.
1996 Capri 1950 no spark from coil-gctid811081
Cycle the kill switch a few times before you do anything else.
Post back !
So, I disconnected the shift interlock plug from distributor and it fired up. Repair manual says to replace magnetic shaft assembly ... which would be distributor. Can it be run without the shift interlock plug plugged in? I'm thinking about trying the module before pulling distributor.
