Two questions about a 2651-gctid811026
    Hi Guy's, I have a 1988 2651 that I'm doing a restoration on along with a new engine installation.
    A couple of questions if I may, there is a plastic tube running from beneath the intergrated boarding platform into the hull.
    Tube is approx 1/2" in diameter and wasn't connected to anything on either end. What is this for?
    2nd question regards the exhaust. Installing a new engine and exhaust system and wondering as the old motor had a 6" exhaust riser extension, do I need to put one on the new engine?
    A couple of questions if I may, there is a plastic tube running from beneath the integrated boarding platform into the hull.
    [color]blue wrote:
    I would need to see a photo![/color]
    [color]blue wrote:
    Perhaps do the math and see where the water line is with regard to the low point of the elbow exhaust path.
    If the exhaust elbows had spacers/risers underneath them, the previous owner most likely had good reason!
    Just for clarity, here is an exhaust Manifold, Spacer/Riser and Elbow.
    The spacer/riser is typically used:
    ..... to control water reversion when a hull sits lower-than-normal in the water
    ..... to separate the manifold from Non-Ported elbow in a Full Closed Cooling System scenario
    In this scenario (below) the spacer/riser is being used to gain Elbow height only. [/color]
    [attachment]36905 wrote:
    Exhaust riser space vs elbow explained 5 .jpg[/attachment]
      Have attached a couple of photos of the tube.
      Thanks for the information re the riser, I will put one on.
        Where does the tube exit?
        Could it be a home-made wiring "chase" for some other sending unit or device, like a fish finder?
          Definately a home made something. It could have been used to feed some sort of fish well but the way it sits now looks like a good way to sink your boat inch:
            Thanks for your imput guys, think I will fibreglass the hole up so we don't sink!!
