My readings on my tank monitor are no longer changing. All three readings show the same level even though the levels are changing. For example tank one and two (fresh water) tanks won't move even when adding and using water. The black water tank also stays exactly the same level. Any advice on how to fix greatly appreciated! This is on a 06 490.
Tank Monitor problem-gctid811002
More input please. What monitor, how is it wired, etc.
[email protected]
[email protected]
Yes it lights up and I did put a 12 volt tester on the black water and it showed it had power. Now to make it even stranger the black water levels are starting to dance around. Went from 24 to 44 percent in about 10 minutes without the toilets ever actually being used. I called the factory and he suggested I remove the sender and clean it. Really hoping there is another option...
Once I began reading your last post I was also thinking pull and clean. Personally I don't know if a WEMA is the right fit for a poop tank. Lots of nasty stuff can get stuck in between the doughnut and the shaft but cleaning it would definitely help. At least that one shows some life. I'd pull all 3 of them and exercise them while someone is watching the monitor. It requires a little work but not all that difficult.
Also test the wires on the fresh water tanks.
Dan
Frostbite Falls, Minnesota
Claudia V. III
1988 - 3218
Gas Drives
