need help asap-gctid810988
    i had an ablative bottom paint on my boat.the guy i hired put hard fiberglass xxx on top which is not compatible
    tomorrow im blasting the bottm
    how far should i go
    up to old ablative ?
    up to the old primer ?
    up to the gelcoat ?
    whats next ?
    i will be on the water all year in the fraser river bc (shelter island marina)
    i lost already $1100 for this bottom paint but this time i want to do it properly
    so my question is
    after blasting what i should do ?
    sand the remaining with 80 grit ?
    then whats the next step ?
    right now i have fiberglass xxx over the ablative paint of which i dont know
    im blasting those two paints so i could apply a proper paint for my conditions
    in the marina they recommend interlux csc but im not going to use the boat very often
    Thank U for any comments
    My opion as a professional auto painter in my past life. If you put paint over another and it wasn't compatible it ALLas to come off. The new and the old as the new non compatible paint chemically damaged the old paint and it's bond.
    1989 Avanti 3450 Sunbridge
    twin 454's
    MV Mar-Y-Sol
    Twin chevy 350's inboard
    Ben- Jamin
    spokane Washington
      thank u but this is not auto body
      i asked specific questions about boats and anti fouling paints of which boat owners could give me the the answers if the like to do it
        The principles may still be the same but I'm no expert. You may wish to reach out to neilw who owes or operates a marina and has passed his knowledge on bottom paint many times on this forum. Good luck and keep us posted.
        "Martini's Law" SOLD
        Nova Scotia, Canada
          Yachtman is correct. Not sure what the fiberglass xxx is you noted in your original post, but you need to take it back to the gelcoat then apply at least 2 coats of bottom paint. If it were me, I would not breath the paint coming off. It is nasty stuff.
          Personally, I like ablative bottom paint. That is what is on my boat in salt water year around. It works very good. But, your location (asking your dock neighbors) will dictate what is working well in your area.
          1992 3288, twin Hino 150's sold
          S. Puget Sound
            Are you referring to http://www.yachtpaint.com/can/diy/pr...ottomkote XXX, or http://www.yachtpaint.com/can/diy/pr...ss Bottomkote?
            If Bottomkote XXX, http://www.yachtpaint.com/MPYACMData... /> read this.
            If Fiberglass Bottomkote, http://www.yachtpaint.com/MPYACMData... /> read this.
            Both of these can be applied over existing bottom paint, as long as the paint isn't loose or flaking. Not sure what your issue is.
            MMSI: 367637220
            HAM: KE7TTR
            TDI tech diver
            Kevin
              after the blasting today i will go with
              Pettit Protect High Build Epoxy Primer (only 2 coats needed )
              then
              2 coats of pet tit horizons
              pettit protect requires 2 coats of paint compare to 5-6 coats of interlux 2000e
              then i can paint with 2 coats pettit horizons
              thats my findings
              whats ur opinions ???
                then 2 coats of pet tit horizons
                How far did you take it down?
                Have you checked the BC regulations regarding using Copper based bottom paint? Horizons has 40.5% Cuprous Oxide.http://www.cleanboatingfoundation.or...t in WA State. By January 1, 2018, it will no longer be allowed to be used on boats under 65'.
                MMSI: 367637220
                HAM: KE7TTR
                TDI tech diver
                Kevin
                  to the gel coat
                  this paint sells for canada only
