Good morning everyone. It's been a while.
7.4, Bravo 2, Full-closed cooling. Last year I drained my coolant to accomplish some maintenance. After I reassembled it, I had an issue with getting a little dribble of coolant around one of the bolt heads. It wasn't much of a leak, so I lived with it. I had sealed the bolt threads with thread sealer with PTFE, the same stuff I used to seal the head bolts. Mercruiser specs that for head bolts and I figured it would work fine for the thermostat bolts also. I also never replaced the thermostat while I had it apart last year and because I wasn't sure of its age, I decided to replace it this year.
Question 1: The thermostat I purchased came with several gaskets and an o-ring. I already purchased the gaskets I need (shown) for my "thermostat sandwich" but I'm wondering now if I should be using either the round cork gasket and/or the O-ring that came with the thermostat. My hunch is that I shouldn't. I did not see one when I removed it last year.
Question 2: What product should I use the seal the bolt threads? I have Permatex Aviation Form-a Gasket (the brown stinky stuff) and every other kind of sealer known to man.
