I am in the process of bringing a long neglected 1979 Bayliner Saratoga back to life. I've found that the trim limit and position sender wires are completely rotted out and I would like to replace these while I am doing the lower shift cable, gimbal bearing, and bellows. I understand that the trim limit switch is mounted on the port side of my MC-1, and the trim position switch is mounted on the starboard side, and I plan to order kit 805320A03 which includes the trim limit and position switches to replace these. Since I have dual control stations with a trim gauge at each, do I also need to order 805130A6 and use this instead of the trim sender which comes with 805320A03? What is the actual difference between the two?
Brice
1979 Saratoga Command Bridge
MC-1 Outdrive
Mercruiser 260HP 350 CI V8
Brice
MC-1 Outdrive
