Air lock in water heater-gctid810625
    I have a 2004 305, I believe I have an air lock in my water heater. Does anyone have any experience with fixing this problem?
    The system is pressurized by the water pressure pump, you should be able to open the hot side of all valve(s) and turn on the water pressure pump to bleed any air from the water heater.
