I have a volvo engine 4cyl 85single prop.I cant find a # for it in michigan wheel or solas prop its to old for catalog.Im being told it is interchangeable with alpha 1 & 2 am I being told wrong.What s proper# anyone know?????
Volvo prop what is it?-gctid397874
Anyone know oem # ????????
Attached files [img]/media/kunena/attachments/vb/701946=29506-photo.JPG[/img]
waterfox wrote:- 1 wrote:
- I have a volvo engine 4cyl 85single prop. I cant find a # for it in michigan wheel or solas prop its to old for catalog.
- Im being told it is interchangeable with alpha 1 & 2 am I being told wrong.
- What s proper# anyone know?????
- 1 wrote:
- I have to ask.... what is a 85single prop?
- The AQ series Volvo Penta did not port the exhaust thru the prop. Merc does!
- Need at least an engine/drive model number, or perhaps some good photos.
I will go Rick one better. You literally gave us nothing to work with. We need year, model, size, and engine that your boat has. Don't just say you have a volvo penta. What VP do you have?
WE're happy to help you, but we're not clairvoyant.
Oh, and I will infer the model year is 1985 from the gibberish you posted. That means you're running an AQ series Volvo. Whoever told you the props are interchangable with Merc is on crystal meth. They are NOT interchangable, and you need to stop going to whatever business gave you that info because they are likely to screw something else up.
Matt Train
BOC Site Team
Chicagoland, IL
Yes I figured he meant it is a 1985. Wouldn't that be a 270 or 275?
I think we don't have to be harsh. But we do need more info as to what model boat and outdrive.
Short of the 250 and 270, he can use either the long or short hub prop for the Aquamatic Drives.
250/270, the long hub does not work.
Sorry guys I have only ever had mercruiser. I have a 270 outdrive engine model # AQ125B Its a single prop 4cyl the boat is a 1985 Trophy Hardtop He has a # wrote down 7858005770 I apologize for everything not being so complete.I dont know why my picture always turn upside down.
Attached files [img]/media/kunena/attachments/vb/702302=29504-photo.JPG[/img]
How did you get your trailer and boat to stay upside down for the photo? I would have thought that to be near impossible!
waterfox wrote:
Sorry guys I have only ever had mercruiser. I have a 270 outdrive engine model # AQ125B Its a single prop 4cyl the boat is a 85 Trophy Hardtop
Does it use the center locking bolt.... and/or is the prop shaft internally threaded for the keeper bolt?
If so, you have a 275 drive, in which case you can use either the short or long hub propellers.
Regardless of what anyone may tell you, you will be using the short spacer/line cutter.
The prop has ZERO to do with the spacer/line cutter length.
Now we're talking. 1985 2160 Trophy with the AQ125 engine.
Drop those specs to any prop shop, and they should be able to recommend you a prop.
I believe the 4 bangers ran a 14 inch diameter prop, and given the size, I'd speculate 17 inches in pitch.
Cross reference that with a good prop shop. And speaking of....here ya go:
http://www.marinepartsexpress.com/pr...RQodaDA8IA#SP2
Matt Train
BOC Site Team
Chicagoland, IL
