Dog Clutch on Cobra-gctid810175
  • Dog Clutch on Cobra-gctid810175
    Took the boat out yesterday. When I put in forward gear, it shifts beautifully. When I put it in reverse, it's like a clunking hit-and-miss, though the prop does move the boat.
    Do the same 'dogs' work for both forward and reverse?
    I found this page with a description, but I'm having difficulty absorbing how it works. Obviously something slides back and forth, but how does that engage the 'dogs'?
    MMSI: 367637220
    HAM: KE7TTR
    TDI tech diver
    Kevin
    Sounds like a shift cable adjustment/replacement is needed.
    Matt Train
    BOC Site Team
    Chicagoland, IL
      Adjustments I leave to my OMC guy. He did this once already when I first bought the boat.
      As to replacing, do I replace just the cable, or the cable and casing?
      MMSI: 367637220
      HAM: KE7TTR
      TDI tech diver
      Kevin
        Before you replace the cable, have the mechanic readjust the shift linkage. Make sure that this person is familiar with OMC Cobras. Also, do not use the boat until then. All it takes is a few missed shifts for the shift figs to get damaged.
        2013 Boston Whaler 130 SS
        Isla Verde, PR
          Thanks. Chuck, my OMC guy with Olympic Marine in Port Angeles has been working on these outdrives since the late 80's. Guess I'd better take it to him and let him decide what I need.
          MMSI: 367637220
          HAM: KE7TTR
          TDI tech diver
          Kevin
            The Cobra uses a 2 cable system; there is one cable (remote cable) that goes from the shift control to the shift bellcrank on the engine bracket and the other one (transom shift cable) goes from the bellcrank to the transom mount were the cable moves another bellcrank in the pivot housing (the part of the transom mount that the drive bolts on to). The movement of this bellcrank moves a shift rod in the lower unit up and down and this is how F,N and R are selected.
            In the lower unit there are 3 gears; the pinion, fwd and rev. The driveshaft from the upper unit always turns and the pinion is at the end of that. The fwd&rev gears are in constant mesh with the pinion and spin all the time the engine runs. In neutral both fwd&rev gears free wheel on the prop shaft. In between the fwd&rev gears is the sliding dog clutch. It has notches or dogs cast into both ends of it. The gears have corresponding notches in the inner side of each gear. The sliding dog clutch is splined to the prop shaft, when you shift it moves the clutch into engagement with whichever gear you selected. This Locks either fwd or rev to the prop shaft and that is how power is transmitted from the pinion to the prop shaft.
            Problems:
            Transom cable wears and gets sticky then you don't get full engagement which makes it jump out of gear and rounds off the notches.
            Remote cable can slip out of adjustment and then you don't get equal stroke in fwd and rev. This can cause it to shift ok in one gear but not the other.
            The other part of the system is the ESA; this is what lowers the idle speed when shifting from in gear to neutral. Due to the way the notches are cut in the gears and dog clutch, once shifted they tend to stay locked in gear. When you try to shift out of gear with a load on the prop it puts a load on the outer casing of the shift cable. This in turn causes the cable casing to flex the load lever on the engine bracket and that activates the ESA which lowers the idle briefly to 450 or so and allows the gear and dog clutch to disengage and this is how the gearcase shifts to neutral.
            Long Island Sound Region
              Very good advice I own a cobra and are a good outdrive but it doesn't take many mishaps with shifting and grinding to wipe out the gears so make sure your mechanic is fimilar with the omc ,been there and now have a new one with one to be have the forward gears replaced
              1988 flybridge trophy bayliner 2556 ,mercury 5.7 lit. OMC cobra out drive 76 hrs. on new package,
              located in ketchikan ak,name DOMINION
                Give this a peek, choose the section you want to read.
                  [color]blue wrote:
                  Short answer, NO!
                  You will see three gears within the lower gear unit.
                  One "drive" gear and two "driven" gears.
                  Each driven gear incorporates dog clutch engagement teeth just inside of the hypoid gear teeth.
                  The sliding sleeve (the part that creates the engagement) incorporates corresponding dog clutch engagement teeth at either end.
                  When the sliding sleeve is moved foward (causing the dog clutch teeth to engage), you will have FWD propeller motion.
                  Likewise for REV when the sliding sleeve is moved AFT.
                  I agree with the guys who have suggested having the adjustment made!
                  Whether OMC Cobra or Merc A drive, the Dog Clutch principle is very much the same. [/color]
                  [attachment]36719 wrote:
                  Dog Clutch dove tail cut 2C.jpg[/attachment]
                  [attachment]36720 wrote:
                  Dog Clutch image how it works 3 .jpg[/attachment]
                  Volvo Penta Duo Prop Drives
                    Excellent, Rick. Thank you. I've printed the photos. Great description. I'm still going to let my mechanic adjust it, but at least I now know what he'll be doing.
                    MMSI: 367637220
                    HAM: KE7TTR
                    TDI tech diver
                    Kevin
                      Easily explained here...
