Hi Group, I just reinstalled the house battery bank on our Carver. It consists of (2) 6 volt batteries. They are hooked up to the number 1 side of the one of the battery shut off switches. There was a single 12 volt battery hooked the number 2 side (traced the battery cable). The 12 volt is being replaced, It's shot. My plan is replace it with (2) 6 volt batteries and wire the windlass to them. is this a workable plan? The other battery shut off switch is set up for the engine starting batteries. We also have a Hearth inverter/charger installed. I need to look at the paperwork for it to see what my charging options are. Thanks Jim
Battery plus Windlass Question-gctid809190
