I have a Volvo 570A (Chevy 350) original stock carb was a 4150 Holley;
I installed a new Holley 4150 Marine Avenger; it bolts up EXCEPT for the throttle bracket.
Holley suggested LOKAR or some other company for the connector but it seems nobody has one available.
Old Volvo Part numbers are 855747 Replaced by 856839,856876 but none of these are in stock at any dealers or online source I could find.
Does anybody have an idea for an alternative part? I'd like to keep the originall 33C cables, but the best I can figure is find a way to use a Mercury cable and re-cable, possibly need a new control box.
This old thread here shows the connector; a king of recangular thing that has a hole in it to accomodate additional throw from the 33C, mounted on a side plate to the carb with rivets.
http://www.baylinerownersclub.org/in...estions#218659
Any ideas how to get one of these or a suitable replacement for the new 4150 carb?
I might try to drill out the rivets and bolt on, but I was hoping we could find a replacement or a source for the 855747, 856839, or 856876 that were designed to work with the holley carbs.
Part 2 of the question; the carb base gasket is another volvo part I cannot find; it looks like a half inch spacer; can I remove it and just put a paper base gasket, or should I be worried about losing the insulation property of the spacer and boiling over fuel?
Much thanks in advance.
1990 Volvo 570A (Chevy 350)
