Maintenance specs-gctid809063
    I have a 2011 3.0 mercruiser tks. Doing oil change and spark plug change. Does anyone know the NGK (plug)code and the FRAM (oil filter)codes. Thanks.
    I like AC Delco OEM plug, but
    NGK BPR6EFS
      Stick with the OEM plug. Being a retired engineer, here's why I do so in my boat.
      When this engine is spec'ed out by the engineers, they try many plugs. The one they chose gave the best all around performance of all they tried. And they have a lot better test instrumentation better than we do. Moreover, if say, NGK says (whatever) is the equivalent, it may not be an exact equivalent and lack a parameter.
      A case in point. My engine calls for MR43LTS and it runs great with them. Some years back, the mercy dealer told me that merc factory bulletin said a certain NGK plug boosted performance, so I tried a set. The engine sounded like 3 cylinders went out on strike. I put the ACs back in and it ran properly. I took the plugs back and we compared them. The AC plug had nearly a3/8" inch more "reach". Reach is the distance from the seal ring to the electrodes inside the engine. Too little, the plug was firing in the threaded areas, and not firing off the air fuel mix properly.. Too much is possible to hit a piston and something breaks and rattles in the engine causing damage. The dealer was cool about it. refunded my money and gave me a set of MR43LTS.
      Point is: as said, sometime saying equivalent/better is spoken by that companies marketing group; not their engineering.
      Captharv 2001 2452
        Fram PH30
        supertech st30
        wix51046, wix51069, 51086, 51087
        napa 1046,1086,1087
        purolator per12, per49,
        acdelco pf12, pf2525,
        motorcraft FL10, FL775
        sierra 18-7824
        The long lengths are: Mobil m1-302
        Fram hp4, ph5, ph13, ph373
        wix51060-51061-51794
        napa1060-1061-1069
        per40,
        per84pf11, pf35 pf1218, (pf832-932)FL308
        sierra 18-7877
        Mercruiser #14957
        QuickSilver #35-802885Q
        PHRAM #PH6606
        WIX #51086
        • Seattlekev
          Seattlekev commented
          Good day sir! I am wondering if the specs have changed from year to year. This thread is for a 2011 and I have a 3.0 from a 2007. Same plugs and filters? Thanx in advance!
        Tip:
        When changing filters (engine oil and/or fuel), use a permanent marking pen and write the date and engine hours onto the cartridge itself.
          Tip ... Spray paint the filter a few coats.
            I have never heard that before. What is the purpose?
            Parry Sound, Ontario Canada
            12 foot aluminum fishing boat
              keeps the can from rusting.
                For what it's worth guys, 2007 185 Bowrider 3.0 Merc takes a AC Delco MR43LTS SPARK PLUG.
