I replaced the lines going to the trim tabs because they were cracked and looked like they would go at any minute. When I did that the fluid came out of the cylinders which I expected but when I powered the system back up, I hear the pump working the well is full and I don't see the tabs moving. According to the manual all you have to do is fill the reservoir and keep trying to lower and raise them until they fill and move. I would hate to keep doing it and burn out the pump. Has anyone bled the system and then primed it up again? It seems like it should have worked the way I did it but its not for some reason.
Thanks.
Thanks.
