I timed my new 5.7 to 10 degrees.I accelerated to 2500 rpm and it only advanced 3 or 4 degrees,is this normal,if not how do I fix
timing advance-gctid808418
"bkc914" post=808421 wrote:
you need about 30 deg of adv at 3000, is it a mech dist or electronic???
All Mercruiser TB are electronic.
I get 15 degrees on timing tape at 2500 rpm,i disconnect ground from purple wire and restart.I now have 14 degrees at idle instead of 10
No need to disconnect anything or jumper wire on the TB 4. Warm engine, set it at 8 degrees btdc at 650-700 rpm.
http://www.boatfix.com/merc/bullet/95/95_11.PDF
Pages11-12
5.0-5.7 engines using TB 4 with module 22
8 degrees btdc
BTW,just wondering when I set base timing by grounding purple wire,do I disconnect it after that and run through my advance time or keep it in?
Spaceman there is no grounding required while setting base timing on a TB 4 ignition system. Grounding the purple/white is for TB 5 only.
