Hey all,
I'm a noob, so forgive my limited knowledge for now. I'm doing my best to try to get up to speed ASAP. I just purchased my first boat (2003 Bayliner Ciera 245 with the 5.0 220HP), and in general I could not be happier with the boat. As I've noticed from other threads though, some people feel that these boats are underpowered and get bogged down ..especially with heavier loads (say more than 4 people, full fuel/water tanks, gear, etc.). I'm having the same problem, but even when it's just me, the boat won't go over 30KTS, and the engine RPM is pegged at 4000. It's also very slow to get on plane under heavy load. I'm wondering if this may be a prop issue. I have no idea what the prop is (standard 3 blade is what I see), but I'm wondering if it's not the most ideal for the boat. Perhaps it's too big or the pitch isn't the most ideal? I'd like to upgrade to something that will maximize performance. Not necessarily top speed, but something that will get up on plane faster maybe? I've seen some pretty fancy schmancy props out there like ones that look like a corkscrew? Seem to be two props stacked into one? Are these better? I definitely want to stick with aluminum as there tends to be debris in the waters around Vancouver. If anyone has any recommendations (especially 245 owners) and what has worked for them, I'm all ears. Thanks so much!
-Michael
-Michael
