Trim limit sender-gctid808201
    Hello
    Need some help
    Where do i connect the 2 wires from the trim limit sender to the trimpump?
    Laszlo
    It will be entering thru upper part of the inner gimbal shield...
      I mean on the trimpump
        My mistake sorry
          No need to apologize
          Blue/white goes to the UP solenoid,
          Green/white goes to the DOWN solenoid.
            They don't connect at the pump. Trim limit switch (puck) wires enter the engine bay through the gimbal housing and connect into the existing harness off the back of the engine. Connection on the transom near the distributor usually.
              Little plastic fitting holds the connected wires, looks like this.
