Hello everyone.
I have a 2003 Bayliner 305SB and I notice that the starboard outboard drive oil starts reduce level very fast and the alarm goes off. Pull the boat out of the water, inspect and found that the Lower unit is full of oil and the leak is coming from inside. I can see the drops coming through the middle when you have the unit trimmed up.
Try to access from inside but could not see. inside the bilge there is no oil leaking.
Does anyone know how to approach in this case?
